Parting out a 1972 F100
- wndsofchng06
Re: Parting out a 1972 F100
fan, rear window stainless, and headlight harnesses. Rear window glass sold
- wndsofchng06
Brake pedal assembly, gas pedal
- wndsofchng06
Made some edits to the original post. Plus windshield stainless is sold. Also now willing to part the engine out. Its got the cold weather carb heater with correct manifold fitting for coolant lines.
- wndsofchng06
Reduced all the prices. Check edits in original post.
- stonebystone
Do you have the steering column bracket that bolts to the outside of the firewall?
I'm converting my '67 to Saginaw PS. Thanks!
- wndsofchng06
I am sorry I do not have that... sold it with the whole column.
wndsofchng06, does this have drum or disc brakes in the front?
1969 F100, 390, 3 Speed, 2WD
- wndsofchng06
Drum. I dont think discs were on f100s until 73
Pic of rims?
1970 F250 460 C6 - Project - Currently not running.
1999 Dodge Durango SLT 4 x 4 5.9 Magnum -not running.
1999 Toyota Corolla - Daily Driver.
https://fordification.com/forum/app.php ... y/album/43
- cstoyer
Would this truck have the dash trim around the switches on either side of the column?
68 F250 4x4
- wndsofchng06
do you mean the faux wood grain aluminum? Yes. But someone spray painted it at some point.....
- cstoyer
- stonebystone
Do you have the engine perches? I need the big block (FE) driver side perch for a power steering (Saginaw) truck. Still working on converting my '67 to power steering. Thanks.
- wndsofchng06
After taking them off and cleaning up a bit, they are too far gone. Some have really deep pitsDisneysPatB wrote:Pic of rims?
- wndsofchng06
Pulled the rear springs , interesting bracketry on these..
