SPEEDOMETER NOISES
edmccloughloch
SPEEDOMETER NOISES
Post by edmccloughloch »
Today I finished the interior of my truck - put back in the instrument cluster, and put on a new speedometer cable. The cable was previously cut by me on the side of the road because it was making a ridiculously loud noise....I thought it might be just loose somewhere...but never did fix that...and now that I put on the new cable, the same noise happens. It sounds like the cable is spinning out of control in there or something.....the needle does move but very erratically. Does this sound like a busted speedometer or should I try and tighten the cable more??
The Landlord: "Are you guys starting an automobile repair shop out of my house or something?"
"No, these are all our cars."
"The three of you have eleven cars???"
re: SPEEDOMETER NOISES
Sounds to me like your cable is just dry. When it's dry, rather than spinning easily, it binds and then pops loose and then does it again....so your speedometer needle jumps around as the cable pops loose. You just need to disconnect your speedo cable at the instrument panel and lubricate it from that end. You'll want to use graphite as a lubricant and not oil or grease. However, working in the graphite can really be a PIA. You could try some oil if you lose your patience, but you might want to consider just replacing it, especially since they're less than $20 at most auto parts stores.
edmccloughloch
the cable in there now is brand new and I put whatever lubricant came with the cable along the full length of the cable. Ill try some graphite...
72hiboy4x4
Location: As far away as I can be from Wa state, without crossing the Mississippi
Post by 72hiboy4x4 »
could the driven gears in the transmission be stripped out? pretty simple to check- just pull the cable out from the tranny and see if your new cable end is stripped. there is a gear inside there also, that might be stripped. my 2C
flyboy2610
Post by flyboy2610 »
You really only need to tighten the speedo cable coupling abot 1/2-3/4 turn past finger tight.
67effie
Post by 67effie »
Just a thought I had this same problem and my problem was that it wasn't correctly attached to the dash.
If at first you don't succeed. Get another beer.
Jeremy
1972 F-100 - currently under going complete frame off restoration
1997 Mustang GT Convertible- (gone but not forgotten, damn unemployment)
1996 Saleen S281 #247
1988 - Coupe, OSP car sold to public NEW, under construction, 1 of 3 that was supposed to go to Saleen in 1988.
http://www.fordification.com/galleries/ ... ?album=270
DDfab
Post by DDfab »
my 69 used to do that in the winter when i first took off, after a few miles of crazy speedo it stopped. was nice to do 0-100 in half a second
lobuck76
Post by lobuck76 »
Mine did the same thing with the new cable. turns out the cable is just a little too long for the shuck. When I snugged it up just handy it would bind up and the speedometer needle would jump. I just loosened the thumbnut quite a bit and it acted ok. I planned on sliding the cable out and taking about a 16th off with the benchgringder. I'll get around to it one of these days. :roll:
'71 F-100
19674x4
Post by 19674x4 »
am i correct that on a 67 highboy the speedo cable attaches at the but end of the transfer case right before the yolk?
My Photo Album
2012 Cummins-the luxury Tow Pig
1967 F-250 highboy 352, np435(((((((sold))))))))) My first true love
1968 F100 SWB. 360, np-435, flatbed, currently acting as a hornest nest and bee hive.
1971 F-100 4x4 Step-side. 360, np-435, 70k origional miles- needs allot of love.
adam138
Post by adam138 »
My truck has been doing that every morning when I take it to school it makes a scratching noise and goes crazy.I think because its cold.Because afterschool when it warms up outside it doesnt make noise.
it may be starting to get bad. take and put some graphite in it now before it messes up. it might save some bull later.
heep70
Re: re: SPEEDOMETER NOISES
Post by heep70 »
19674x4 wrote:am i correct that on a 67 highboy the speedo cable attaches at the but end of the transfer case right before the yolk?
YEP.
These cable are no longer available. A shop has to build them for you. "Highboys" only. Read below.
http://fordification.com/forum/viewtopi ... eedo+cable
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
