Brake system light
Brake system light
How does the brake system warning light come out of the dash? Does the lens/bezel screw off, or is there a retainer behind the dash? You can't hardly get your hand up there with the emergency brake in the way. When I bought my truck the whole thing was missing. I found one in a parts truck, but I want to get it out without damaging it.
69 F-100 Ranger 302
re: Brake system light
I know it's a socket like a 2 prong light bulb. I'm pretty sure you will have to push from the back while you twist counter clockwise, then the front chrome ring slides off the socket.
It's been awhile but I know they really are not that hard to remove once you figure it out. I actually took another from a junk yard and replaced the blank space where a cigarette lighter would have gone if mine was so equipped. Then I used a washer and inserted this light for an indicator for when my overdrive is on. It looks really stock that way!!
Steve
69 F100 300I6
67 Mustang fb FE 431ci
72 Gran Torino Sport 351W
91 Bronco 351
69 F100 300I6
91 Bronco 351
- heatmiser
Yep, just hold the bezel with your left hand, reach up under the dash with your right. Push in and twist about 1/4-turn and remove.
